The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
security session limit application create
PDF of this doc site
Creating your file...
Your file is ready
Create per-application session limit
This command allows creation of a per-application management session limit that does not yet exist.
-interface {cli|ontapi|rest}
- Interface (privilege: advanced)-
The interface (CLI, ONTAPI, or REST) to which the limit applies.
-application <text>
- Application (privilege: advanced)-
The specified application to which this limit applies. The limit with the application name
-default-
is the limit used for any application without a specific configured limit. -max-active-limit <integer>
- Max-Active Limit (privilege: advanced)-
The maximum number of concurrent sessions allowed for this interface and application.
The following example illustrates creating a limit for management sessions from a custom application.
cluster1::*> security session limit application create -interface ontapi -application "custom_app" -max-active-limit 8
