Command reference
network interface failover-groups delete
Delete a failover group
The network interface failover-groups delete command deletes a logical interface failover group.
-vserver <vserver> - Vserver Name
Use this parameter to specify the name of the Vservers from which this failover group is accessible.
-failover-group <text> - Failover Group Name
Use this parameter to specify the name of the logical interface failover group to be deleted.
The following example shows how to delete a failover group named failover-group_2.
cluster1::> network interface failover-groups delete -vserver vs1 -failover-group failover-group_2
