statistics top file show
Most actively accessed files
This command continuously displays performance data for top files at a regular interval. The command output displays data in the following columns:
Total IOPS - total number of input/output operations per second.
Node - node name.
Vserver - vserver name.
Aggregate - aggregate name.
Volume - volume name.
File - file name.
[-node {<nodename>|local}]- Node-
Selects the node for which you want to display performance data.
[-sort-key <text>]- Column to Sort By-
If this parameter is specified, the command displays statistics sorted by the specified column.
-interval <integer>- Interval-
Specifies, in seconds, the interval between statistics updates. The default setting is 30 seconds.
-iterations <integer>- Iterations-
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
-max <integer>- Maximum Number of Instances-
Specifies maximum number of top files to display. The default setting is 10.
The following example displays top files statistics:
cluster1::> statistics top file show
cluster-1 : 12/31/1969 16:00:04
*Estimated
Total
IOPS Node Vserver Aggregate Volume File
9 cluster-node2 vserver01 aggr1 vol01 /vol/vol01/clus/cache
6 cluster-node1 vserver02 aggr2 vol02 /vol/vol02
