Command reference
snapmirror policy modify-rule
Modify an existing rule in SnapMirror policy
The snapmirror policy modify-rule command can be used to modify the retention count, preserve setting, warning threshold count, schedule, and prefix for a rule in a SnapMirror policy. Reducing the retention count or disabling the preserve setting for a rule in a SnapMirror policy might result in the deletion of snapshots on the vault destination when the next transfer by the snapmirror update command occurs or when the next scheduled snapshot creation on the destination for the rule occurs. Modifying a rule to add a schedule will enable creation of snapshots on the SnapMirror destination. snapshots on the source that have a SnapMirror label matching this rule will not be selected for transfer. Schedule and prefix can only be modified for rules associated with SnapMirror policies of type vault or mirror-vault . A SnapMirror policy with rules must have at least one rule without a schedule.
Note The rules in SnapMirror policies of type async-mirror cannot be modified.
-vserver <vserver name> - Vserver Name
Specifies the Vserver for the SnapMirror policy.
-policy <sm_policy> - SnapMirror Policy Name
Specifies the SnapMirror policy name.
-snapmirror-label <text> - Snapshot Copy Label
This parameter specifies the rule that is to be modified in a SnapMirror policy.
[-keep <text>] - Snapshot Copy Retention Count
Specifies the maximum number of snapshots that are retained on the SnapMirror destination volume for a rule. The total number of snapshots retained for all the rules in a policy cannot exceed 1019. For all the rules in SnapMirror policies of type async-mirror , this parameter must be set to value 1 .
[-preserve {true|false}] - Snapshot Copy Preserve Enabled
Specifies the behavior when the snapshot retention count is reached on the SnapMirror vault destination for the rule. The default value is false , which means that the oldest snapshot will be deleted to make room for new ones only if the number of snapshots has exceeded the retention count specified in the "keep" parameter. When set to true , and when the snapshots have reached the retention count, then an incremental SnapMirror vault update transfer will fail or if the rule has a schedule, snapshots will no longer be created on the SnapMirror destination. For all the rules in SnapMirror policies of type async-mirror this parameter must be set to value false .
[-warn <integer>] - Warning Threshold Count
Specifies the warning threshold count for the rule. The default value is 0 . When set to a value greater than zero, an event is generated after the number of snapshots (for the particular rule) retained on a SnapMirror vault destination reaches the specified warn limit. The preserve parameter for the rule must be true to set the warn parameter to a value greater than zero.
[-schedule <text>] - Snapshot Copy Creation Schedule
This optional parameter specifies the name of the schedule associated with a rule. This parameter is allowed only for rules associated with SnapMirror policies of type vault or mirror-vault . When this parameter is specified, snapshots are directly created on the SnapMirror destination. The snapshots created will have the same content as the latest snapshot already present on the SnapMirror destination. snapshots on the source that have a SnapMirror label matching this rule will not be selected for transfer. The default value is - .
Note You define and name a schedule using the job schedule cron create command.
In a cascaded volume relationship, a policy configured with a rule using this parameter is supported only on the final SnapMirror destination volume in the cascade.
[-prefix <text>] - Snapshot Copy Creation Prefix
This optional parameter specifies the prefix for the snapshot name to be created as per the schedule. If no value is specified, then the snapmirror-label will be used as the prefix. The prefix parameter can only be specified for rules which have a schedule.
[-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}] - Snapshot Copy Retention Period
This optional parameter specifies the duration for which the snapshots associated with this rule will be locked. The parameter is specified as a number followed by a suffix. The valid suffixes are seconds , minutes , hours , days , months , and years . For example, a value of 6months represents a retention period of 6 months. It can also be set to a special value of infinite for infinite retention. The destination volume must have the snapshot-locking-enabled parameter set to true for this field to take effect else it will be ignored.
The following example changes the retention count for nightly snapshots to 6 for a rule named nightly on a SnapMirror policy named TieredBackup on Vserver vs0.example.com :
vs0.example.com::> snapmirror policy modify-rule -vserver vs0.example.com
        -policy TieredBackup -snapmirror-label nightly -keep 6
