Command reference
security session limit location modify
Modify per-location session limit
This command allows modification of a per-location management session limit.
-interface {cli|ontapi|rest} - Interface (privilege: advanced)
The interface (CLI, ONTAPI, or REST) to which the limit applies.
-location <text> - Location (privilege: advanced)
The specified location to which this limit applies. The limit with the location name -default- (in the Default IPspace) is the limit used for any location (in any IPspace) without a specific configured limit.
[-ipspace <IPspace>] - IPspace of Location (privilege: advanced)
This identifies the IPspace of the client location. If not specified, changes are made in the Default IPspace.
[-max-active-limit <integer>] - Max-Active Limit (privilege: advanced)
The maximum number of concurrent sessions allowed for this interface and location.
The following example illustrates modifying management sessions limits for specific locations.
cluster1::*> security session limit location modify -interface * -location 10.98.* -max-active-limit 2
3 entries were modified.
