security session limit location modify
Modify per-location session limit
This command allows modification of a per-location management session limit.
- -interface {cli|ontapi|rest}- Interface (privilege: advanced)
The interface (CLI, ONTAPI, or REST) to which the limit applies.
- -location <text>- Location (privilege: advanced)
The specified location to which this limit applies. The limit with the location name -default-(in theDefaultIPspace) is the limit used for any location (in any IPspace) without a specific configured limit.
- [-ipspace <IPspace>]- IPspace of Location (privilege: advanced)
This identifies the IPspace of the client location. If not specified, changes are made in the DefaultIPspace.
- [-max-active-limit <integer>]- Max-Active Limit (privilege: advanced)
The maximum number of concurrent sessions allowed for this interface and location.
The following example illustrates modifying management sessions limits for specific locations.
cluster1::*> security session limit location modify -interface * -location 10.98.* -max-active-limit 2 3 entries were modified.
 PDFs
PDFs
