system node image show
Display software image information
The system node image show command displays information about software images. By default, the command displays the following information:
Node name
Image name
Whether the image is the default image
Whether the image is the current image
Software version
Installation date
To display detailed information about a specific software image, run the command with the -node and -image parameters. The detailed view adds information about the kernel image path, and the root file system image path.
You can specify additional parameters to select specific information. For example, to display information only about software images that are currently running, run the command with the -iscurrent true parameter.
[-fields <fieldname>,…]-
If you specify the
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node (privilege: advanced)-
Selects information about the software images on the specified node. If this parameter and the -image parameter are both used, the command displays detailed information about the specified software image.
[-image {image1|image2|remote}]- Image Name (privilege: advanced)-
Selects information about the software images that match the specified name. If this parameter and the -node parameter are specified, the command displays detailed information about the specified software image.
[-isdefault {true|false}]- Is Default Image (privilege: advanced)-
Selects information about the software images with the specified default setting.
[-iscurrent {true|false}]- Is Current Image (privilege: advanced)-
Selects information about the software images that have the specified currency value.
[-kernel-path <text>]- Kernel Image Path (privilege: advanced)-
Selects information about the software images that have the specified kernel image path.
[-rootfs-path <text>]- Root Filesystem Image Path (privilege: advanced)-
Selects information about the software images that have the specified root file system image path.
[-version <text>]- Software Version (privilege: advanced)-
[-installdate <MM/DD/YYYY HH:MM:SS>]- Install Date (privilege: advanced)-
Selects information about the software image that have the specified installation date. Specify the date in the format MM/DD/YYYY HH:MM:SS [+- HH:MM].
The following example displays information about the software images on a node named node1:
cluster1::> system node image show -node node1
Is Is Install
Node Image Default Current Version Date
node1
image1 true true 8.0 8/20/2009 17:42:42
image2 false false 8.0 6/26/2009 17:44:50
2 entries were displayed.
