volume reallocation restart
Restart reallocate job
Starts a reallocation job. Use this command to start a quiesced (temporarily stopped) job or a scheduled scan that is idle.
NOTE:
This command is not supported for FlexGroup volumes or FlexGroup constituents.
-vserver <vserver name>- Vserver-
Specifies the Vserver.
-path <text>- Path-
Specifies the file path of the LUN, NVMe namespace, file, or volume on which you want to restart reallocation scans.
[-i, -ignore-checkpoint <true>]- Ignore Checkpoint-
Restarts the job at the beginning when set to true. If you use this command without specifying this parameter, its effective value is false and the job starts the scan at the point where it stopped. If you specify this parameter without a value, it is set to true and the scan restarts at the beginning.
cluster1::> volume reallocation restart /vol/vol2 2 entries were acted on.
Restarts two reallocation jobs on volume vol2.
