Command reference
network route create
Create a static route
The network route create command creates a static route within a Vserver.
-vserver <vserver> - Vserver Name
Use this parameter to specify the Vserver on which the route is to be created.
-destination <IP Address/Mask> - Destination/Mask
Use this parameter to specify the IP address and subnet mask of the route's destination. The format for this value is: address, slash ("/"), mask. 0.0.0.0/0 is a valid destination value to create default IPv4 route. And ::/0 is a valid destination value to create default IPv6 route
-gateway <IP Address> - Gateway
Use this parameter to specify the IP address of the gateway server leading to the route's destination.
[-metric <integer>] - Metric
Use this parameter to specify the metric of the route.
The following example creates default routes within Vserver vs0 for IPv4 and IPv6.
cluster1::> network route create -vserver vs0 -destination 0.0.0.0/0 -gateway 10.61.208.1
cluster1::> network route create -vserver vs0 -destination ::/0 -gateway 3ffe:1::1
