security dynamic-authorization group create
Add a Dynamic Authorization group
The security dynamic-authorization group create command creates the groups to include in dynamic authorization.
-vserver <vserver name>- Vserver-
This parameter optionally specifies the Vserver of the dynamic authorization group that is being created. If this parameter is specified, the setting applies to that Vserver only. If not specified, the cluster Vserver setting is used.
-name <text>- Group Name-
This parameter specifies the name of the group that will be part of dynamic authorization.
[-excluded-usernames <text>,…]- List of Excluded Users-
This parameter optionally specifies the list of users that will be excluded from dynamic authorization.
[-comment <text>]- Comment-
This parameter optionally specifies the comments.
The following command creates a group test on vserver vs1 and excludes the user tsmith from dynamic authorization.
cluster1::> security dynamic-authorization group create -vserver vs1 -name test -excluded-usernames tsmith
