Command reference
network port ifgrp delete
Destroy a port interface group
The network port ifgrp delete command destroys a port interface group.
Note When you delete an interface group port, it is automatically removed from failover rules and groups to which it belongs.
-node {<nodename>|local} - Node
The node on which the port interface group is located.
-ifgrp <ifgrp name> - Interface Group Name
The port interface group that will be deleted.
The following example deletes port interface group a0b from a node named node0.
cluster1::> network port ifgrp delete -node node0 -ifgrp a0b
