vserver nfs storepool blocked-client show
Display the Storepool Blocked Clients Information
The vserver nfs storepool blocked-client show command shows the NFSv4 storepool blocked clients. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, the command displays the following information about all the blocked clients:
Node on which storepool blocked client cache is present
Client ip address
Time to live for blocked client cache entry
[-fields <fieldname>,…]-
If you specify the
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node Name (privilege: advanced)-
If this parameter is specified, the command displays information only about clients with the specified node.
[-client-ip <IP Address>]- Client IP Address (privilege: advanced)-
If this parameter is specified, the command displays information with the specified client IP.
[-ttl <[<integer>d][<integer>h][<integer>m][<integer>s]>]- TTL For Entries (Secs) (privilege: advanced)-
If this parameter is specified, the command displays all the blocked client information whose time to live matches the provided value.
The following example displays all NFSv4 storepool blocked clients caches which are present on node1.
cluster1::*> vserver nfs storepool blocked-client show -node node1
cluster1::*>
Node: node1
Client-IP TTL (secs)
1.0.1.62 512s
1.0.1.63 512s
1.0.1.126 512s
3 entries were displayed.
cluster1::*>
