Command reference
security webauthn show
Show Webauthn Global Settings
The security webauthn show displays information on the global FIDO2/WebAuthn settings.
{ [-fields <fieldname>,…​]
Selects the fields that you specify.
| [-instance ] }
Displays all the fields for the global WebAuthn settings.
[-vserver <vserver name>] - Vserver
Selects the WebAuthn settings that match this parameter value. If not specified, all cluster-level and Vserver-level settings are displayed.
[-timeout <integer>] - Timeout (ms)
Displays all the fields for the FIDO2/WebAuthn global settings.
[-attestation {none|indirect|direct|enterprise}] - Attestation Conveyance Type
[-require-rk {true|false}] - Require Resident Key
[-resident-key {required|preferred|discouraged}] - Resident Key
[-user-verification {required|preferred|discouraged}] - User Verification
[-scope {svm|cluster}] - Cluster or SVM
[-rp-domains <text>,…​] - Relying Party Domain List
The example below displays information on FIDO2/WebAuthn global settings:
cluster1::> security webauthn show
Vserver: cluster1
               Timeout (ms): 600000
Attestation Conveyance Type: none
       Require Resident Key: false
               Resident Key: discouraged
          User Verification: discouraged
  Relying Party Domain List: domain.com
