vserver cifs domain password schedule show
Display the domain account password change schedule
The vserver cifs domain password schedule show command displays the domain account password change schedule configuration. It displays the following fields:
Vserver: Vserver for which the schedule is configured
Schedule Enabled: Whether the schedule is enabled or disabled for this Vserver
Schedule Interval: Weeks after which the password change schedule occurs again for this Vserver
Schedule Randomized Within: Minutes within which the schedule must begin for this Vserver
Schedule: Password change schedule currently set on this Vserver
Last Successful Password Change/Reset Time: Time at which the last password change or reset happened successfully on this Vserver
Warning: Warning message, applicable only when the change password job is deleted with the feature still enabled on this Vserver
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays information for the specified Vserver.
[-is-schedule-enabled {true|false}]- Is Password Change Schedule Enabled-
If you specify this parameter, the command displays information for all the Vservers on which the is-schedule-enabled value applies.
[-schedule-weekly-interval <integer>]- Interval in Weeks for Password Change Schedule-
If you specify this parameter, the command displays information for all the Vservers on which the schedule-weekly-interval value applies.
[-schedule-randomized-minute <integer>]- Minutes Within Which Schedule Start Can be Randomized-
If you specify this parameter, the command displays information for all the Vservers on which the schedule-randomized-minute value applies.
[-schedule-last-changed <text>]- Last Successful Password Change/Reset Time-
If you specify this parameter, the command displays information for all the Vservers on which the schedule-last-changed value applies.
[-schedule-description <text>]- Schedule Description-
If you specify this parameter, the command displays information for all the Vservers on which the schedule-description value applies.
[-schedule-warn-msg <text>]- Warning Message in Case Job Is Deleted-
If you specify this parameter, the command displays information for all the Vservers on which the schedule-warn-msg value applies.
The following example shows the domain account password change schedule configuration when the password change feature is enabled for Vserver vs1.
cluster1::> vserver cifs domain password schedule show
Vserver: vs1
Schedule Enabled: true
Schedule Interval: 4 week
Schedule Randomized Within: 120 min
Schedule: Fri@23:00
Last Changed At: Thu Apr 4 02:35:23 2013
The following example shows the domain account password change schedule configuration when the password change job has been accidentally deleted.
Vserver: vs1
Schedule: Fri@23:00
Warning: Password change job was deleted. Re-enable the password change schedule.
