system configuration backup create
Create a configuration backup
The system configuration backup create command creates a new configuration backup file.
-node {<nodename>|local}- Node (privilege: advanced)-
Use this parameter to specify the node on which to create the backup file.
[-backup-name <text>]- Backup Name (privilege: advanced)-
Use this parameter to specify the name of the backup file to create. The backup name cannot contain a space or any of the following characters: * ? /
[-backup-type {node|cluster}]- Backup Type (privilege: advanced)-
Use this parameter to specify the type of backup file to create.
The following example creates a new cluster configuration backup file called node1.special.7z on the node node1 .
cluster1::*> system configuration backup create -node node1 -backup-name node1.special.7z -backup-type cluster [Job 194] Job is queued: Cluster Backup OnDemand Job V2.
