Command reference
security dynamic-authorization show
Show dynamic-authorization global settings
The security dynamic-authorization show displays information on dynamic authorization settings.
{ [-fields <fieldname>,…​]
Selects the fields that you specify.
| [-instance ] }
Displays all the fields for the dynamic authorization settings.
[-vserver <vserver name>] - Vserver
Selects the dynamic authorization settings that match this parameter value. If not specified, all cluster-level and Vserver-level settings are displayed.
[-state {disabled|visibility|enforced}] - Dynamic Authorization State
[-suppression-interval {P[<integer>D]T[<integer>H][<integer>M][<integer>S] | P<integer>W | disabled}] - Dynamic Authorization Suppression Interval
[-lower-challenge-boundary <percent>] - Lower MFA Challenge Boundary
[-upper-challenge-boundary <percent>] - Upper MFA Challenge Boundary
The example below displays information on dynamic authorization settings:
cluster1::> security dynamic-authorization show
Vserver: cluster1
                          Dynamic Authorization State: disabled
           Dynamic Authorization Suppression Interval: 10m
                         Lower MFA Challenge Boundary: 0%
                         Upper MFA Challenge Boundary: 90%
