Command reference
volume flexcache config show
Display cache configuration
The `volume flexcache config show` command is used to view the FlexCache configuration for a FlexCache volume.
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-vserver <Vserver Name>] - Vserver Name (privilege: advanced)
If this parameter and the -volume parameter are specified, the command displays config information about the specified volume. If this parameter is specified by itself, the command displays information about FlexCache volumes on the specified Vserver.
[-volume <volume name>] - Cache Volume Name (privilege: advanced)
If this parameter is specified, the command displays config information about the specified FlexCache volumes matching the specified name.
[-is-cifs-enabled {true|false}] - Is CIFS Access Enabled (privilege: advanced)
If this parameter is specified, the command displays the FlexCache volumes matching the value for CIFS access.
[-is-nfsv4-enabled {true|false}] - Is NFSv4 Access Enabled (privilege: advanced)
If this parameter is specified, the command displays the FlexCache volumes matching the value for NFSv4 access.
[-is-writeback-enabled {true|false}] - Is Writeback Enabled (privilege: advanced)
If this parameter is specified, the command displays the FlexCache volumes matching the writeback mode. Writeback is a storage method where data is first written to the FlexCache volume and then written to the origin of a FlexCache volume.
[-is-relative-size-enabled {true|false}] - Is Relative Sizing Enabled (privilege: advanced)
If this parameter is specified, the command displays the FlexCache volumes matching the value for relative size.
[-relative-size-percentage <integer>] - Relative FlexCache Size Percentage (privilege: advanced)
If this parameter is specified, the command displays the FlexCache volumes matching the percentage for relative size.
[-is-atime-scrub-enabled {true|false}] - Is atime based Scrubbing Enabled/Disabled (privilege: advanced)
If this parameter is specified, the command displays the FlexCache volumes matching the atime scrubbing mode.
[-atime-scrub-period <integer>] - Days after which an inactive file is scrubbed (privilege: advanced)
If this parameter is specified, the command displays the FlexCache volumes matching the period for atime scrubbing.
[-is-cifs-change-notify-enabled {true|false}] - Is CIFS CHANGE_NOTIFY Enabled/Disabled (privilege: advanced)
If this parameter is specified, the command displays the FlexCache volumes matching the value for CIFS CHANGE_NOTIFY mode.
[-is-s3-enabled {true|false}] - Is S3 Access Enabled (privilege: advanced)
If this parameter is specified, the command displays the FlexCache volumes matching the value for S3 access.
[-is-mtime-scrubber-enabled {true|false}] - Is Mtime Scrubber Enabled/Disabled (privilege: advanced)
If this parameter is specified, the command displays the FlexCache volumes matching the value for mtime scrubber mode.
[-mtime-scrubber-threshold <integer>] - Mtime Scrubber idle time in seconds (privilege: advanced)
If this parameter is specified, the command displays the FlexCache volumes matching the threshold for mtime scrubber.
The following example triggers FlexCache volume configuration show:
cluster1::> flexcache config show
  (volume flexcache config show)
Vserver Volume      CIFS Access Enabled
vs1     cachevol    false
vs1     cachevol_2  true
2 entries were displayed.
