volume flexcache config show
Display cache configuration
The `volume flexcache config show` command is used to view the FlexCache configuraiton for a FlexCache volume.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name (privilege: advanced)-
This specifies the Vserver in which the FlexCache volume exists.
[-volume <volume name>]- Cache Volume Name (privilege: advanced)-
This specifies the name of the FlexCache volume.
[-is-relative-size-enabled {true|false}]- Is Relative Sizing Enabled (privilege: advanced)-
This parameter specifies whether the relative sizing is allowed on a FlexCache volume.
[-relative-size-percentage <integer>]- Relative Flexcache Size Percentage (privilege: advanced)-
This parameter specifies the percent size FlexCache should have relative to the total size of the origin.
The following example triggers FlexCache volume configuration show:
cluster1::> flexcache config show (volume flexcache config show) Vserver Volume CIFS Access Enabled ------- ----------- ------------------ vs1 cachevol false vs1 cachevol_2 true 2 entries were displayed.
