volume flexcache config show
Display cache configuration
The `volume flexcache config show` command is used to view the FlexCache configuraiton for a FlexCache volume.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name (privilege: advanced)-
If this parameter and the
-volumeparameter are specified, the command displays config information about the specified volume. If this parameter is specified by itself, the command displays information about FlexCache volumes on the specified Vserver. [-volume <volume name>]- Cache Volume Name (privilege: advanced)-
If this parameter is specified, the command displays config information about the specified FlexCache volumes matching the specified name.
[-is-cifs-enabled {true|false}]- Is CIFS Access Enabled (privilege: advanced)-
If this parameter is specified, the command displays the FlexCache volumes matching the value for CIFS access.
[-is-nfsv4-enabled {true|false}]- Is NFSv4 Access Enabled (privilege: advanced)-
If this parameter is specified, the command displays the FlexCache volumes matching the value for NFSv4 access.
[-is-writeback-enabled {true|false}]- Is Writeback Enabled (privilege: advanced)-
If this parameter is specified, the command displays the FlexCache volumes matching the writeback mode. Writeback is a storage method where data is first written to the FlexCache volume and then written to the origin of a FlexCache volume.
[-is-relative-size-enabled {true|false}]- Is Relative Sizing Enabled (privilege: advanced)-
If this parameter is specified, the command displays the FlexCache volumes matching the value for relative size.
[-relative-size-percentage <integer>]- Relative FlexCache Size Percentage (privilege: advanced)-
If this parameter is specified, the command displays the FlexCache volumes matching the percentage for relative size.
[-is-atime-scrub-enabled {true|false}]- Is atime based Scrubbing Enabled/Disabled (privilege: advanced)-
If this parameter is specified, the command displays the FlexCache volumes matching the atime scrubbing mode.
[-atime-scrub-period <integer>]- Days after which an inactive file is scrubbed (privilege: advanced)-
If this parameter is specified, the command displays the FlexCache volumes matching the period for atime scrubbing.
[-is-cifs-change-notify-enabled {true|false}]- Is CIFS CHANGE_NOTIFY Enabled/Disabled (privilege: advanced)-
If this parameter is specified, the command displays the FlexCache volumes matching the value for CIFS CHANGE_NOTIFY mode.
The following example triggers FlexCache volume configuration show:
cluster1::> flexcache config show (volume flexcache config show) Vserver Volume CIFS Access Enabled ------- ----------- ------------------ vs1 cachevol false vs1 cachevol_2 true 2 entries were displayed.
