job schedule interval show
Show interval schedules
The job schedule interval show command displays information about interval schedules.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-cluster <Cluster name>]- Cluster-
Selects the interval schedules that match this parameter value.
[-vserver <vserver name>]- Vserver-
Selects the interval schedules that match this parameter value. These job schedules can only be used by consumers in that Vserver.
[-name <text>]- Name-
[-days <integer>]- Days-
Selects the interval schedules that match the day value or range of values you specify.
[-hours <integer>]- Hours-
Selects the interval schedules that match the hour value or range of values you specify.
[-minutes <integer>]- Minutes-
Selects the interval schedules that match the minute value or range of values you specify.
[-seconds <integer>]- Seconds-
Selects the interval schedules that match the second value or range of values you specify.
[-description <text>]- Description-
Selects the interval schedules that match the description you specify.
The following example displays information about all interval schedules:
cluster1::> job schedule interval show
Cluster Vserver Name Description
cluster1 data_vs_1
rollingdaily
Every 8h
