Command reference
job schedule show
Display a list of available schedules
The job schedule show command displays information about schedules.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-cluster <Cluster name>] - Cluster
Selects the schedules that match this parameter value.
[-vserver <vserver name>] - Vserver
Selects the schedules that match this parameter value. These job schedules can only be used by consumers in that Vserver.
[-name <text>] - Schedule Name
[-type {cron|interval|builtin}] - Schedule Type
[-description <text>] - Description
The following example displays information about all schedules:
cluster1::> job schedule show
Cluster       Vserver     Name         Type     Description
cluster1
              data_vs_1
                          5min        cron      @:00,:05,:10,:15,:20,:25,:30,:35,:40,:45,:50,:55
                          daily       cron      @0:10
                          hourly      cron      @:05
                          monthly     cron      1@0:20
                          weekly      cron      Sun@0:15
