job schedule show
Display a list of available schedules
The job schedule show command displays information about schedules.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-cluster <Cluster name>]- Cluster-
Selects the schedules that match this parameter value.
[-vserver <vserver name>]- Vserver-
Selects the schedules that match this parameter value. These job schedules can only be used by consumers in that Vserver.
[-name <text>]- Schedule Name-
[-type {cron|interval|builtin}]- Schedule Type-
[-description <text>]- Description-
The following example displays information about all schedules:
cluster1::> job schedule show
Cluster Vserver Name Type Description
cluster1
data_vs_1
5min cron @:00,:05,:10,:15,:20,:25,:30,:35,:40,:45,:50,:55
daily cron @0:10
hourly cron @:05
monthly cron 1@0:20
weekly cron Sun@0:15
