vserver cifs session show
Display established CIFS sessions
The vserver cifs session show command displays information about established CIFS sessions. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following information about all CIFS sessions:
Node name
Vserver name
CIFS connection ID
CIFS session ID
Workstation IP address
CIFS user name
CIFS open files
Session idle time
You can specify additional parameters to display only information that matches those parameters. For example, to display information only about CIFS sessions established on connection ID 2012, run the command with the `-connection-id parameter set to ` 2012.
[-fields <fieldname>,…] -
If you specify this parameter, the command only displays the fields that you specify.
[-active-volumes ] -
If you specify this parameter, the command displays the list of Volumes that session has been connected.
[-show-win-unix-creds ] -
If you specify this parameter along with a valid session-id, the command displays Windows and UNIX credentials along with the detailed information about matching CIFS sessions.
[-instance ]} -
If you specify this parameter, the command displays detailed information about matching CIFS sessions.
[-node {<nodename>|local}]- Node-
If you specify this parameter, the command displays information about the CIFS sessions on the specified node.
[-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays information about CIFS sessions on the specified CIFS-enabled Vserver.
[-session-id <integer>]- Session ID-
If you specify this parameter, the command displays information about the CIFS session that match the specified session ID.
[-connection-id <integer>]- Connection ID-
If you specify this parameter, the command displays information about CIFS sessions that match the specified connection ID.
[-lif-address <IP Address>]- Incoming Data LIF IP Address-
If you specify this parameter, the command displays information about CIFS sessions that are established through the specified data LIF IP address.
[-address <IP Address>]- Workstation IP address-
If you specify this parameter, the command displays information about CIFS sessions that are opened from the specified IP address.
[-auth-mechanism <Authentication Mechanism>]- Authentication Mechanism-
If you specify this parameter, the command displays information about CIFS sessions that used the specified authentication mechanism. The authentication mechanism can include one of the following:
None - Could not authenticate
NTLMv1 - NTLMv1 authentication mechanism
NTLMv2 - NTLMv2 authentication mechanism
Kerberos - Kerberos authentication mechanism
Anonymous - Anonymous authentication mechanism
[-windows-user <TextNoCase>]- Windows User-
If you specify this parameter, the command displays information about CIFS sessions that are established for the specified CIFS user. The acceptable format for CIFS user is [domain]\user.
[-unix-user <text>]- UNIX User-
If you specify this parameter, the command displays information about CIFS sessions that are established for the specified UNIX user.
[-shares <integer>]- Open Shares-
If you specify this parameter, the command displays information about CIFS sessions that have the specified number of CIFS shares opened.
[-files <integer>]- Open Files-
If you specify this parameter, the command displays information about CIFS sessions that have the specified number of regular CIFS files opened.
[-other <integer>]- Open Other-
If you specify this parameter, the command displays information about CIFS sessions that have the specified number of special CIFS files opened such as streams or directories.
[-connected-time <[<integer>d][<integer>h][<integer>m][<integer>s]>]- Connected Time-
If you specify this parameter, the command displays information about CIFS sessions that are established for the specified time duration.
[-idle-time <[<integer>d][<integer>h][<integer>m][<integer>s]>]- Idle Time-
If you specify this parameter, the command displays information about CIFS sessions on which there is no activity for the specified time duration.
[-protocol-version <CIFS Dialects>]- Protocol Version-
If you specify this parameter, the command displays information about CIFS sessions that are established over the specified version of CIFS protocol. The protocol version can include one of the following:
SMB1 - SMB 1.0
SMB2 - SMB 2.0
SMB2_1 - SMB 2.1
SMB3 - SMB 3.0
SMB3_1 - SMB 3.1
[-continuously-available <CIFS Open File Protection>]- Continuously Available-
If you specify this parameter, the command displays information about CIFS sessions with open files that have the specified level of continuously available protection. The open files are "continuously available" if they are opened from an SMB 3 client through a share with the "continuously_available" property set. These open files are capable of non-disruptively recovering from takeover and giveback as well as general aggregate relocation between partners in a high-availability relationship. This is in addition to the traditional SMB 2 capability allowing clients to recover from LIF migration and other brief network interruptions.
The CA protection levels depict the continuous availability at the connection level so it might not be accurate for a session if the connection has multiple sessions. Streams opened through a continuously available share are permitted, but are not currently made continuously available. Directories may be opened through a continuously available share, but, by design, will not appear continuously available as clients do not open them that way. These protection levels are applicable to the sessions on read/write volumes residing on storage failover aggregates. The continuously available status can be one of the following:
No - The session contains one or more open file but none of them are continuously available.
Yes - The session contains one or more open files and all of them are continuously available.
Partial - The session contains at least one continuously available open file but other open files that are not.
[-is-session-signed {true|false}]- Is Session Signed-
If you specify this parameter, the command displays information about CIFS sessions that are established with the specified SMB signing option.
[-user-type {local-user|domain-user|guest-user|anonymous-user|hybrid-user}]- User Authenticated as-
If you specify this parameter, the command displays information about CIFS sessions that are established for the specified user type. The user type can include one of the following:
local-user - Authenticated as a local CIFS user
domain-user - Authenticated as a domain user
guest-user - Authenticated as a guest user
anonymous-user - Authenticated as an anonymous or null user
hybrid-user - Authenticated as a hybrid user (A domain user synced to Azure Entra ID)
[-netbios-name <text>]- NetBIOS Name-
If you specify this parameter, the command displays information about CIFS sessions that are established with the specified NetBIOS Name.
[-smb-encryption-status {unencrypted|encrypted|partially-encrypted}]- SMB Encryption Status-
If you specify this parameter, the command displays information about CIFS sessions that are established with the specified SMB encryption status.
The SMB encryption status can be one of the following:
unencrypted - The CIFS session is not encrypted.
encrypted - The CIFS session is fully encrypted. Vserver level encryption is enabled and encryption happens for the entire session.
partially-encrypted - The CIFS session is partially encrypted. Share level encryption is enabled and encryption is initiated when the tree-connect occurs.
[-connection-count <integer>]- Connection Count-
If you specify this parameter, the command displays information about CIFS sessions that have the specified number of CIFS connections.
[-is-large-mtu-enabled {true|false}]- Is Large MTU Enabled-
If you specify this parameter, the command displays information about CIFS sessions that are established with the specified Large MTU option.
[-vol-names <volume name>,…]- Volumes List-
If you specify this parameter, the command displays information about CIFS sessions that are established with the specified volume names.
[-share-names <Share>,…]- Open Shares Lists-
If you specify this parameter, the command displays information about CIFS sessions that are established including the specified share names.
The following example displays information about all CIFS sessions:
cluster1::> vserver cifs session show
Node: node1
Vserver: vs1
Connection Session Open Idle Connection
ID ID Workstation Windows User Files Time Count
127834 1 172.17.193.172 CIFSQA\ 2 22s 4
Administrator
The following example displays information about a CIFS session with session-id 1.
cluster1::> vserver cifs session show -session-id 1 -instance
Node: node1
Vserver: vs1
Session ID: 1
Connection ID: 127834
Incoming Data LIF IP Address: 10.53.13.224
Workstation: 172.17.193.172
Authentication Mechanism: NTLMv2
Windows User: CIFSQA\Administrator
UNIX User: root
Open Shares: 2
Open Files: 2
Open Other: 0
Connected Time: 2d 17h 58m 5s
Idle Time: 22s
Protocol Version: SMB3
Continuously Available: No
Is Session Signed: true
User Authenticated as: domain-user
NetBIOS Name: ALIAS1
SMB Encryption Status: encrypted
Connection Count: 4
Windows Unix Credentials: -
Active Volumes: vol1,fg
