Command reference
vserver export-policy config-checker show
Show the status of export policy configuration checker jobs
The vserver export-policy config-checker show command displays status information about export policy configuration checker job. This command displays the following information:
  • Vserver name
  • Export policy name
  • Export policy configuration checker job state
  • Export policy rule checked count
  • Export policy rule being checked rule index
  • Export policy rule with issue count
Note This command output will only be available after running the export policy configuration checker job.
{ [-fields <fieldname>,…​]
If you specify the -fields parameter, the command only displays the fields that you specify.
| [-instance ] }
If you specify the -instance parameter, the command displays detailed information about all entries.
[-vserver <vserver name>] - Vserver
If you specify this parameter, the command displays export policy configuration checker job state information for Vservers that match the specified value.
[-policy <export policy name>] - Policy Name
If you specify this parameter, the command displays export policy configuration checker job state information for policy that match the specified value.
[-rules-checked <integer>] - Number of Rules Checked
If you specify this parameter, the command displays export policy configuration checker job state information that have the specified rules-checked count matching.
[-rule-being-checked <integer>] - Rule Being Checked
If you specify this parameter, the command displays export policy configuration checker job state information that have the specified rule-being-checked index matching.
[-rules-with-issues <integer>] - Number of Rules with Issues
If you specify this parameter, the command displays export policy configuration checker job state information that have the specified rules-with-issues count matching.
[-state {Initial|Queued|Running|Waiting|Pausing|Paused|Quitting|Success|Failure|Reschedule|Error|Quit|Dead|Unknown|Restart|Dormant}] - Job State
If you specify this parameter, the command displays export policy configuration checker job state information that have the specified state matching.
The following example displays an export policy configuration checker job state information for vserver vs2 and policy default:
cluster1::> vserver export-policy config-checker show -vserver vs2 -policy default
Job       Rules     Rule Index    Rules With
Vserver    Policy     State     Checked   Being Checked Issues
vs2        default    Running   1         2             1
