vserver export-policy config-checker show
Show the status of export policy configuration checker jobs
The vserver export-policy config-checker show command displays status information about export policy configuration checker job. This command displays the following information:
Vserver name
Export policy name
Export policy configuration checker job state
Export policy rule checked count
Export policy rule being checked rule index
Export policy rule with issue count
|  | This command output will only be available after running the export policy configuration checker job. |
- { [-fields <fieldname>,…]
If you specify the -fieldsparameter, the command only displays the fields that you specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all entries.
- [-vserver <vserver name>]- Vserver
If you specify this parameter, the command displays export policy configuration checker job state information for Vservers that match the specified value.
- [-policy <export policy name>]- Policy Name
If you specify this parameter, the command displays export policy configuration checker job state information for policy that match the specified value.
- [-rules-checked <integer>]- Number of Rules Checked
If you specify this parameter, the command displays export policy configuration checker job state information that have the specified rules-checked count matching.
- [-rule-being-checked <integer>]- Rule Being Checked
If you specify this parameter, the command displays export policy configuration checker job state information that have the specified rule-being-checked index matching.
- [-rules-with-issues <integer>]- Number of Rules with Issues
If you specify this parameter, the command displays export policy configuration checker job state information that have the specified rules-with-issues count matching.
- [-state {Initial|Queued|Running|Waiting|Pausing|Paused|Quitting|Success|Failure|Reschedule|Error|Quit|Dead|Unknown|Restart|Dormant}]- Job State
If you specify this parameter, the command displays export policy configuration checker job state information that have the specified state matching.
The following example displays an export policy configuration checker job state information for vserver vs2 and policy default:
cluster1::> vserver export-policy config-checker show -vserver vs2 -policy default Job Rules Rule Index Rules With Vserver Policy State Checked Being Checked Issues ---------- ---------- --------- --------- ------------- ------------- vs2 default Running 1 2 1
 PDFs
PDFs
