system license capacity show
(DEPRECATED)-Show license capacity status
This command is deprecated and may be removed in a future release of ONTAP. Use the "system license show-status " command. |
The system license capacity show command displays the information about the licenses in the system that are specifically related to storage capacity limits.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-serial-number <Node Serial Number>]- Serial Number-
If you use this parameter, the command displays information only about the capacity-related licenses that matches the serial number you specify.
[-package <Licensable Package>]- Package-
If you use this parameter, the command displays information only about the package you specify.
[-owner <text>]- Owner-
If you use this parameter, the command displays information only about the capacity-related licenses that have the owner you specify.
[-max-capacity {<integer>[KB|MB|GB|TB|PB]}]- Maximum Capacity-
If you use this parameter, the command displays information only about the capacity-related licenses that have the maximum amount of attached storage capacity you specify.
[-current-capacity {<integer>[KB|MB|GB|TB|PB]}]- Current Capacity-
If you use this parameter, the command displays information only about the capacity-related licenses that apply to the node with the current attached capacity you specify.
[-expiration <MM/DD/YYYY HH:MM:SS>]- Expiration Date-
If you use this parameter, the command displays information only about the capacity-related licenses that have the expiration date you specify.
[-reported-state {evaluation|warning|missing|enforcement|installed}]- Reported State-
If you use this parameter, the command displays information only about the capacity-related licenses that have the reported state you specify.
[-node {<nodename>|local}]- Node Name-
If you use this parameter, the command displays information only about the capacity-related licenses that apply to the node you specify.
The following example displays information about all capacity-related licensed packages in the cluster, for a hypothetical cluster of four nodes:
Note that for some nodes below, the maximum capacity is displayed as "-" (meaning "unlimited"). This happens when there is no capacity license for the node - the node is operating with a limited-time temporary capacity license.
cluster1::> system license capacity show
Node: node1
Serial Number: 1-81-0000000000001234567890123456
Max Current
Package Capacity Capacity Expiration
Select 2TB 15.81GB 4/11/2016 00:00:00
Node: node2
Serial Number: 1-81-0000000000000000000123456788
Max Current
Select - 10.40TB 4/11/2016 00:00:00
Node: node3
Serial Number: 1-81-0000000000000000000123456789
Max Current
Node: node4
Max Current
