Command reference
system controller pcicerr threshold show
Display the Node PCIe error alert threshold
The system controller pcicerr threshold show command displays information about node-wide PCIe correctable error threshold counts in the cluster.
The example below displays the information about node-wide PCIe error threshold count in the cluster:
cluster1::> system controller pcicerr threshold show
PCIe Error Threshold
                    200
