system controller pcicerr threshold show
PDF of this doc site
Creating your file...
Your file is ready
Display the Node PCIe error alert threshold
The system controller pcicerr threshold show
command displays information about node-wide PCIe correctable error threshold counts in the cluster.
The example below displays the information about node-wide PCIe error threshold count in the cluster:
cluster1::> system controller pcicerr threshold show PCIe Error Threshold ----------------------- 200
