cluster add-node-status-clear-failed
Remove failed nodes from the status list
The cluster add-node-status-clear-failed
command removes failed entries from the status list displayed by the cluster add-node-status command.
The following example removes failed entries:
clus1::> cluster add-node-status Node Name Cluster IP Status Error Reason ---------------- ------------------- ------------------- -------------------------- - 2.2.2.2 failure The cluster port MTU values do not match. Retry cluster create or join after updating the cluster port MTUs to the same value. node1 1.1.1.1 success 2 entries were displayed. clus1::> cluster add-node-status-clear-failed clus1::> cluster add-node-status Node Name Cluster IP Status Error Reason ---------------- ------------------- ------------------- -------------------------- node1 1.1.1.1. success
