security webauthn credentials show
Show Webauthn Credentials Data
The security webauthn credentials show displays information on the FIDO2/WebAuthn registered credentials.
[-fields <fieldname>,…] -
Selects the fields that you specify.
[-instance ]} -
Displays all the fields for the FIDO2/WebAuthn registered credentials.
[-vserver <vserver name>]- Vserver-
Selects the FIDO2/WebAuthn registered credentials that match this parameter value. Only cluster-level credentials are supported at this time.
[-username <text>]- Username-
[-index <integer>]- Index-
[-rpId <text>]- Relying Party ID-
[-credential-id-sha <text>]- SHA-256 Hashed Credential ID-
[-publickey-algorithm <text>]- Public Key Algorithm-
[-publickey <text>]- Public Key-
[-display-name <text>]- Display Name-
[-credential-type <public-key>]- Credential Type-
[-rpName <text>]- Relying Party Name-
[-creation-time <MM/DD/YYYY HH:MM:SS>]- Creation Time-
[-last-used <MM/DD/YYYY HH:MM:SS>]- Last Used-
[-scope {svm|cluster}]- Cluster or SVM-
The example below displays information on the FIDO2/WebAuthn registered credentials:
cluster1::> security webauthn credentials show
Vserver: cluster1
Username: admin
Index: 0
Relying Party ID: myontap.example.com
SHA-256 Hashed Credential ID: aaaaaaaaaaaaaaaaaaaaaaaaaaa
Public Key Algorithm: ES256
Public Key: abcd=
Display Name: admin
Credential Type: public-key
Relying Party Name: myontap.example.com
Creation Time: 6/10/2024 15:01:00
Last Used: 6/10/2024 15:01:00
