snapmirror protect
Start protection for Vservers and volumes
The snapmirror protect command establishes SnapMirror protection for the specified Vserver or a list of volumes. For each endpoint, the command creates a data protection destination endpoint in the Vserver specified by the -destination-vserver parameter, creates an extended data protection (XDP) SnapMirror relationship, and starts the initialization of the SnapMirror relationship. This command must be used from the destination Vserver or cluster. This command is not supported for FlexGroup volume constituents or non ONTAP endpoints. When source volumes are specified they must be read-write (RW) volumes.
[-source-cluster <Cluster name>]- Source Cluster-
This optional parameter specifies the source cluster name. This parameter is valid only when only a single Vserver is specified in the path-list parameter.
-path-list {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[app-cgname]>}- Path List -
This parameter specifies the list of source endpoints to be protected. The list is a comma separated list of paths of the form
vserver:volumeorvserver:, for examplevs1.example.com:dept_eng1, vs1.example.com:dept_eng2orvs1.example.com:. If the list contains a Vserver endpoint, then the Vserver is the only endpoint that can be specified, and the list cannot contain a mixture of volume and Vserver endpoints. - |
-source-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[app-cgname]>}- Source Path } -
This optional parameter specifies the path of the source endpoint to be protected. This parameter is valid only when
-path-listparameter is not specified. This is the alias of-path-listparameter. [-destination-vserver <vserver name>]- Destination Vserver-
This parameter specifies the Vserver in which to create the destination volumes of the SnapMirror relationships. When protecting a single Vserver, this parameter specifies the destination Vserver endpoint for protection.
[-destination-vserver-ipspace <IPspace>]- Destination Vserver IPSpace Name-
This optional parameter specifies the IPspace the Vserver will be assigned to. If left unspecified, the Vserver will be assigned to the default IPspace. This parameter is supported while protecting a Vserver.
[-schedule <text>]- SnapMirror Schedule-
This optional parameter designates the name of the schedule which is used to update the SnapMirror relationships.
[-policy <sm_policy>]- SnapMirror Policy-
This parameter designates the name of the SnapMirror policy which is associated with the SnapMirror relationships. The default value is
MirrorAndVault. [-auto-initialize {true|false}]- Auto Initialize-
This optional parameter specifies whether or not initializes of the SnapMirror relationships should be started after the relationships are created. The default value for this parameter is
true. [-destination-volume-prefix <text>]- Destination Volume Name Prefix-
This optional parameter designates the prefix for the destination volume name. For example if the source path is of the form
vserver:volumeand the destination-volume-prefix specified isprefixand no destination-volume-suffix is specified, then the destination volume name will be_prefix_volume_dstor possiblyprefix_volume_1_dstif a name conflict is encountered. If both prefix and suffix are specified asprefixand__suffix, then the destination volume name will beprefix_volume_suffixorprefix_volume_1_suffix, if a name conflict is encountered. This parameter is not supported for Vserver endpoints. [-destination-volume-suffix <text>]- Destination Volume Name Suffix-
This optional parameter designates the suffix for the destination volume name. If you do not designate a suffix, a destination volume name with suffix
dst_will be used. For example if the source path is of the formvserver:volume, and the suffix specified isDP_, the destination volume will be created with the namevolume_DPorvolume_1_DPif a name conflict is encountered. If both prefix and suffix are specified asprefixandsuffix, then the destination volume name will beprefix_volume_suffixorprefix_volume_1_suffix, if a name conflict is encountered. This parameter is not supported for Vserver endpoints. [-support-tiering {true|false}]- Provision Destination Volumes on FabricPools-
This optional parameter specifies whether or not FabricPools are selected when provisioning a FlexVol volume or a FlexGroup volume during protection workflows. When this parameter is set to true, only FabricPools are used; when set to false, only non-FabricPools are used. Tiering support for a FlexVol volume can be changed by moving the volume to the required aggregate. Tiering support for a FlexGroup volume can be changed by moving all of the constituents to the required aggregates. The default value is
false. This parameter is supported only for FlexVol volumes and FlexGroup volumes. This parameter is supported only if the cluster where the destination is being provisioned is Unified ONTAP. [-tiering-policy <Tiering Policy>]- Destination Volume Tiering Policy-
This optional parameter specifies the tiering policy to apply to the destination FlexVol volume or FlexGroup volume. This policy determines whether the user data blocks of a FlexVol volume or FlexGroup volume in a FabricPool will be tiered to the capacity tier when they become cold. FabricPool combines flash (performance tier) with an object store (external capacity tier) into a single aggregate. The default tiering policy is
snapshot-onlyfor a FlexVol volume andnonefor a FlexGroup volume. The temperature of a FlexVol volume or FlexGroup volume block increases if it is accessed frequently and decreases when it is not.The available tiering policies are:
snapshot-only - This policy allows tiering of only the FlexVol volume or FlexGroup volume snapshots not associated with the active file system. The default minimum cooling period is 2 days. The
-tiering-minimum-cooling-daysparameter can be used to override the default using thevolume modifycommand after the destination FlexVol volume or FlexGroup volume has been created. -
auto - This policy allows tiering of both snapshot and active file system user data to the capacity tier. The default cooling period is 31 days. The
none - FlexVol volume or FlexGroup volume blocks will not be tiered to the capacity tier.
all - On a DP FlexVol volume or FlexGroup volume this policy allows all transferred user data blocks to start in the capacity tier.
[-destination-path {<[vserver:][volume]>|<[[cluster:]//vserver/]volume>|<hostip:/lun/name>|<hostip:/share/share-name>|<[vserver:]/cg/[app-cgname]>}]- Destination Path-
This optional parameter specifies the path of the destination endpoint to be created. This parameter is valid only when a single path is specified in the
-path-listparameter. If this parameter is specified, the-destination-vserver,-destination-object-store,-destination-volume-prefix, and-destination-volume-suffixparameters cannot be specified. [-destination-snaplock-type {non-snaplock|compliance|enterprise}]- Destination Volume SnapLock Type-
Optional parameter to create the destination endpoint with the specified SnapLock type for establishing a SnapMirror relationship. This parameter is only supported for relationships with the SnapMirror policy of type
vault [-default-retention-period {{<integer> seconds|minutes|hours|days|months|years} | min | max | infinite | unspecified}]- Default Retention Period-
Specifies the default retention period that is applied to snapshots while committing them to the locked state without an associated retention period. This parameter is only supported when the
-destination-snaplock-typetype is specified. [-minimum-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}]- Minimum Retention Period-
Specifies the minimum allowed retention period for snapshots committed to the locked state on the volume. This parameter is only supported when the
-destination-snaplock-typetype is specified. [-maximum-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}]- Maximum Retention Period-
Specifies the maximum allowed retention period for snapshots committed to the locked state on the volume. This parameter is only supported when the
To establish SnapMirror protection for the source volumes vs1.example.com:dept_eng1 and vs1.example.com:dept_eng2 using destination-vserver vs2.example.com and policy MirrorAllSnapshots type the following command:
vs2.example.com::> snapmirror protect -path-list
vs1.example.com:dept_eng1,vs1.example.com:dept_eng2 -destination-vserver
vs2.example.com -policy MirrorAllSnapshots
To establish SnapMirror protection for the source Vserver vs1.example.com which is on cluster cluster1 creating a destination-vserver named vs1dp.example.com and using policy MirrorAllSnapshots type the following command:
cluster2::> snapmirror protect -source-cluster cluster1 -path-list vs1.example.com: -destination-vserver vs1dp.example.com -policy MirrorAllSnapshots
To establish SnapMirror protection for the source Consistency Group endpoint vs1.example.com:/cg/cg1 which is on cluster cluster1 creating a destination Consistency Group vs2.example.com:/cg/cg1_dst and using policy MirrorAndVault type the following command:
cluster2::> snapmirror protect -path-list vs1.example.com:/cg/cg1 -policy MirrorAndVault
