system node autosupport trigger modify
Modify AutoSupport trigger configuration
Use the system node autosupport trigger modify command to enable and disable AutoSupport messages for individual triggers, and to specify additional subsystem reports to include if an individual trigger sends an AutoSupport message.
This command cannot be used to modify "dcn.callhome" or "de.callhome" event settings (except -suppress parameter).
-node {<nodename>|local}- Node-
Use this parameter to specify the node whose AutoSupport trigger configuration is modified.
-autosupport-message <Autosupport Message>- EMS Message-
Use this parameter to specify the AutoSupport trigger to modify. AutoSupport triggers are EMS messages whose names begin with "callhome.". However, for the purposes of this command, "callhome." is implied, does not need to be entered, and will not be displayed in command output.
[-to {enabled|disabled}]- Deliver to AutoSupport -to Addresses-
Use this parameter with the value "enabled" to enable sending AutoSupport messages to the configured "to" addresses.
[-noteto {enabled|disabled}]- (DEPRECATED) Deliver to AutoSupport -noteto Addresses-
This parameter has been deprecated and might be removed in a future version of ONTAP. Instead, use the event notification destination create command to create an email destination and the event notification create command to map the important-eventssystem filter to the newly created event destination. This will send an email notification for all events with a severity of ERROR, ALERT, or EMERGENCY. For events with other severity values, a new event filter needs to be created using the event filter create command. Filter rules can be added to the filter using the event filter rule add command. This newly created filter has to be mapped to the event destination.Use this parameter with the value "enabled" to enable sending short notes to the configured "noteto" addresses.
[-basic-additional <subsys1,subsys2,…>,…]- Additional Subsystems Reporting Basic Info-
Use this parameter to include
basiccontent from the additional subsystems you specify. Content is collected from these subsystems in addition to the default list of subsystems. [-troubleshooting-additional <subsys1,subsys2,…>,…]- Additional Subsystems Reporting Troubleshooting Info-
troubleshootingcontent from the additional subsystems you specify. Content is collected from these subsystems in addition to the default list of subsystems. [-suppress {true|false}]- Suppress all occurrences of this trigger-
Use this parameter with the value "true" to suppress the collection when the AutoSupport message is triggered.
The following example enables messages to the configured "to" addresses from the battery.low trigger on the node node1 .
cluster1::> system node autosupport trigger modify -node node1 -autosupport-message battery.low -to enabled
