vserver fcp wwn blacklist show
Displays the blacklisted WWNs
This command displays WWNs that have been blacklisted from re-use.
A blacklisted WWN is a WWN that is prohibited for use as either a fiber channel protocol service WWNN or a fiber channel data LIF WWPN.
[-fields <fieldname>,…]-
If you specify the
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-wwn <text>]- World Wide Name (privilege: advanced)-
Selects the blacklisted WWNs that match the parameter value.
[-vserver <Vserver Name>]- Vserver Name (privilege: advanced)-
Selects the blacklisted WWNs that were previously assigned to the Vserver(s) that match the parameter value.
cluster1::> vserver fcp wwn blacklist show
WWN Vserver
01:02:03:04:05:06:07:08 vs1
01:02:03:04:05:06:07:09 vs1
2 entries were displayed.
Displays the blacklisted WWNs.
