vserver fcp wwn blacklist show
PDF of this doc site
Creating your file...
Displays the blacklisted WWNs
This command displays WWNs that have been blacklisted from re-use.
A blacklisted WWN is a WWN that is prohibited for use as either a fiber channel protocol service WWNN or a fiber channel data LIF WWPN.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-wwn <text>]
- World Wide Name (privilege: advanced)-
Selects the blacklisted WWNs that match the parameter value.
[-vserver <Vserver Name>]
- Vserver Name (privilege: advanced)-
Selects the blacklisted WWNs that were previously assigned to the Vserver(s) that match the parameter value.
cluster1::> vserver fcp wwn blacklist show WWN Vserver ----------------------- ---------- 01:02:03:04:05:06:07:08 vs1 01:02:03:04:05:06:07:09 vs1 2 entries were displayed.
Displays the blacklisted WWNs.
