Command reference
volume quota policy copy
Copy a quota policy
This command copies a quota policy and the rules it contains.You must enter the following information to copy a quota policy:
  • Vserver name
  • Policy name
  • New policy name
-vserver <vserver name> - Vserver
This parameter specifies the Vserver from which you are copying the quota policy.
-policy-name <text> - Policy Name
This parameter specifies the name of the quota policy you are copying.
-new-policy-name <text> - New Policy Name
This parameter specifies the name of the new quota policy you are copying to. The new name cannot have more than 32 characters.
The following example copies a quota policy named quota_policy_0 on Vserver vs0. It is copied to quota_policy_1.
cluster1::> volume quota policy copy -vserver vs0 -policy-name quota_policy_0 -new-policy-name quota_policy_1
