The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume quota policy copy
PDF of this doc site
Creating your file...
Your file is ready
Copy a quota policy
This command copies a quota policy and the rules it contains.You must enter the following information to copy a quota policy:
Vserver name
Policy name
New policy name
-vserver <vserver name>
- Vserver-
This parameter specifies the Vserver from which you are copying the quota policy.
-policy-name <text>
- Policy Name-
This parameter specifies the name of the quota policy you are copying.
-new-policy-name <text>
- New Policy Name-
This parameter specifies the name of the new quota policy you are copying to. The new name cannot have more than 32 characters.
The following example copies a quota policy named quota_policy_0 on Vserver vs0. It is copied to quota_policy_1.
cluster1::> volume quota policy copy -vserver vs0 -policy-name quota_policy_0 -new-policy-name quota_policy_1
