Command reference
vserver audit audit-log-redirect show
Display Audit Log Redirect Vserver destination
The vserver audit audit-log-redirect show command displays the dedicated Vserver for all audit logs in a cluster to reside in.
The following example displays the audit-log-redirect Vserver:
cluster1::> vserver audit audit-log-redirect show
Audit Log Redirect Vserver: vserver1
