security audit modify
Set administrative audit logging settings
The security audit modify command modifies the following audit-logging settings for the management interface:
Whether get requests for the CLI are audited
Whether get requests for the ONTAP API (ONTAPI) are audited
[-cliget {on|off}]- Enable Auditing of CLI Get Operations-
This specifies whether get requests for the CLI are audited. The default setting is
off. [-httpget {on|off}]- Enable Auditing of HTTP Get Operations-
This specifies whether get requests for the web (HTTP) interface are audited. The default setting is
off. [-ontapiget {on|off}]- Enable Auditing of Data ONTAP API Get Operations-
This specifies whether get requests for the ONTAP API (ONTAPI) interface are audited. The default setting is
off. [-cluster-peer {on|off}]- Enable Auditing of Cross Cluster Operations (privilege: advanced)-
This specifies whether cross cluster operations are audited. The default setting is
on.
The following example turns off auditing of get requests for the CLI interface:
cluster1::> security audit modify -cliget off
