ONTAP 9.13.1 commands
security audit modify
Set administrative audit logging settings
The security audit modify command modifies the following audit-logging settings for the management interface:
  • Whether get requests for the CLI are audited
  • Whether get requests for the Data ONTAP API (ONTAPI) are audited
[-cliget {on|off}] - Enable Auditing of CLI Get Operations
This specifies whether get requests for the CLI are audited. The default setting is off .
[-httpget {on|off}] - Enable Auditing of HTTP Get Operations
This specifies whether get requests for the web (HTTP) interface are audited. The default setting is off .
[-ontapiget {on|off}] - Enable Auditing of Data ONTAP API Get Operations
This specifies whether get requests for the Data ONTAP API (ONTAPI) interface are audited. The default setting is off .
The following example turns off auditing of get requests for the CLI interface:
cluster1::> security audit modify -cliget off
