system controller replace show-details
Display detailed status of controller replacement
The system controller replace show-details command displays detailed information about the currently running and previously run non-disruptive controller replacement operations. The command displays the following information:
Phase
Node
Task name
Task status
Error message
[-fields <fieldname>,…]-
If you specify the
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-operation-identifier {None|Controller-replacement}]- Operation Identifier (privilege: advanced)-
Specifies the NDO operation identifier.
[-task-identifier <integer>]- Task Identifier (privilege: advanced)-
Specifies the identification number of the task.
[-node <nodename>]- Node That Performs Operation (privilege: advanced)-
Specifies the node that is to be replaced.
[-task-phase {None|Initialization|Precheck|Commit|Collect-info|Preop|Resource-release|Verification|Resource-regain|Postop|Uncommit|Postcheck|Cleanup}]- Task Phase (privilege: advanced)-
Specifies the phase of the operation.
[-task-name <text>]- Name of the Task (privilege: advanced)-
Specifies the name of the task.
[-task-status {None|Ready-to-start|In-progress|Waiting|Paused-on-error||Paused-for-intervention|Paused-on-request|Completed-on-first-node|Completed|Failed|Pause_req|Canceled}]- Status of the Task (privilege: advanced)-
Specifies the status of the task.
[-task-error <text>]- Error During the Task Execution (privilege: advanced)-
Specifies the error occurred.
[-task-recovery-action <text>]- Action to Recover from Error (privilege: advanced)-
Specifies the action to be taken in case of error.
The following example displays detailed information about the non-disruptive replacement operation:
cluster1::*> system controller replace show-details
Task Phase Node Task Name Operation-State
Precheck node1 Cluster Health Check Completed
MCC Cluster Check Completed
Aggr Relocation Completed
Status Check
Model Name Check Completed
Cluster Quorum Check Completed
Image Version Check Completed
HA Status Check Completed
Aggregate Status Completed
Check
Disk Status Check Completed
Data LIF Status Check Completed
Cluster LIF Status Completed
Check
ASUP Status Check Completed
CPU Utilization Check Completed
Aggr Reconstruction Completed
Check
Node Affinity Job Completed
Check
Collect-info node1 Verify Details Paused-for-intervention
node2 Verify Details Paused-for-intervention
17 entries were displayed.
