system controller replace show-details
Display detailed status of controller replacement
The system controller replace show-details
command displays detailed information about the currently running and previously run non-disruptive controller replacement operations. The command displays the following information:
Phase
Node
Task name
Task status
Error message
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-operation-identifier {None|Controller-replacement}]
- Operation Identifier (privilege: advanced)-
Specifies the NDO operation identifier.
[-task-identifier <integer>]
- Task Identifier (privilege: advanced)-
Specifies the identification number of the task.
[-node <nodename>]
- Node That Performs Operation (privilege: advanced)-
Specifies the node that is to be replaced.
[-task-phase {None|Initialization|Precheck|Commit|Collect-info|Preop|Resource-release|Verification|Resource-regain|Postop|Uncommit|Postcheck|Cleanup}]
- Task Phase (privilege: advanced)-
Specifies the phase of the operation.
[-task-name <text>]
- Name of the Task (privilege: advanced)-
Specifies the name of the task.
[-task-status {None|Ready-to-start|In-progress|Waiting|Paused-on-error||Paused-for-intervention|Paused-on-request|Completed-on-first-node|Completed|Failed|Pause_req|Canceled}]
- Status of the Task (privilege: advanced)-
Specifies the status of the task.
[-task-error <text>]
- Error During the Task Execution (privilege: advanced)-
Specifies the error occured.
[-task-recovery-action <text>]
- Action to Recover from Error (privilege: advanced)-
Specifies the action to be taken in case of error.
The following example displays detailed information about the non-disruptive replacement operation:
cluster1::*> system controller replace show-details Task Phase Node Task Name Operation-State ---------------- --------------- --------------------- ----------------------- Precheck node1 Cluster Health Check Completed MCC Cluster Check Completed Aggr Relocation Completed Status Check Model Name Check Completed Cluster Quorum Check Completed Image Version Check Completed HA Status Check Completed Aggregate Status Completed Check Disk Status Check Completed Data LIF Status Check Completed Cluster LIF Status Completed Check ASUP Status Check Completed CPU Utilization Check Completed Aggr Reconstruction Completed Check Node Affinity Job Completed Check Collect-info node1 Verify Details Paused-for-intervention node2 Verify Details Paused-for-intervention 17 entries were displayed.
