ONTAP commands
system controller replace show-details
Display detailed status of controller replacement
The system controller replace show-details command displays detailed information about the currently running and previously run non-disruptive controller replacement operations. The command displays the following information:
  • Phase
  • Node
  • Task name
  • Task status
  • Error message
[-fields <fieldname>,…​]
| [-instance ] (privilege: advanced) }
[-operation-identifier {None|Controller-replacement}] - Operation Identifier (privilege: advanced)
Specifies the NDO operation identifier.
[-task-identifier <integer>] - Task Identifier (privilege: advanced)
Specifies the identification number of the task.
[-node <nodename>] - Node That Performs Operation (privilege: advanced)
Specifies the node that is to be replaced.
[-task-phase {None|Initialization|Precheck|Commit|Collect-info|Preop|Resource-release|Verification|Resource-regain|Postop|Uncommit|Postcheck|Cleanup}] - Task Phase (privilege: advanced)
Specifies the phase of the operation.
[-task-name <text>] - Name of the Task (privilege: advanced)
Specifies the name of the task.
[-task-status {None|Ready-to-start|In-progress|Waiting|Paused-on-error||Paused-for-intervention|Paused-on-request|Completed-on-first-node|Completed|Failed|Pause_req|Canceled}] - Status of the Task (privilege: advanced)
Specifies the status of the task.
[-task-error <text>] - Error During the Task Execution (privilege: advanced)
Specifies the error occurred.
[-task-recovery-action <text>] - Action to Recover from Error (privilege: advanced)
Specifies the action to be taken in case of error.
The following example displays detailed information about the non-disruptive replacement operation:
cluster1::*> system controller replace show-details
  Task Phase       Node            Task Name            Operation-State
  Precheck         node1           Cluster Health Check  Completed
                                   MCC Cluster Check     Completed
                                   Aggr Relocation       Completed
                                   Status Check
                                   Model Name Check      Completed
                                   Cluster Quorum Check  Completed
                                   Image Version Check   Completed
                                   HA Status Check       Completed
                                   Aggregate Status      Completed
                                   Check
                                   Disk Status Check     Completed
                                   Data LIF Status Check Completed
                                   Cluster LIF Status    Completed
                                   Check
                                   ASUP Status Check     Completed
                                   CPU Utilization Check Completed
                                   Aggr Reconstruction   Completed
                                   Check
                                   Node Affinity Job     Completed
                                   Check
  Collect-info     node1       Verify Details        Paused-for-intervention
                   node2           Verify Details        Paused-for-intervention
  17 entries were displayed.
