volume snapshot autodelete show
Display autodelete settings
The volume snapshot autodelete show command displays information about snapshot autodelete policies. The command output depends on the parameters specified with the command. If no parameters are specified, the command displays a table with the following information about all the available snapshot autodelete policies:
Vserver name
Volume name
Option name
Option value
To display a detailed list view with additional information, run the command and select the -instance view. The detailed list view provides the following information:
Vserver name
Volume name
Enabled
Commitment
Defer Delete
Delete Order
Defer Delete Prefix
Target Free Space
Trigger
Destroy List
Is Constituent Volume
By using the -fields option you can choose to print only the certain fields in the output. This presents the selected fields in a table view. This is ideal when you want additional information to be different from the information that is provided by the default table view, but would like it in a format which is visually easy to compare.
You can specify additional parameters to display the information that matches only those parameters. For example, to display information only about snapshot autodelete policies which are enabled, run the command with -enabled true parameter. If you specify multiple filtering parameters, only those policies that match all the specified parameters are displayed.
[-fields <fieldname>,…] -
This option allows you to print only certain fields in the output.
[-instance ]} -
This option allows you to print a detailed list view.
[-vserver <vserver name>]- Vserver Name-
If this parameter and the
-volumeparameter are specified, the command displays detailed autodelete policy information about the specified volume. If this parameter is specified by itself, the command displays autodelete policy information about volumes on the specified Vserver. [-volume <volume name>]- Volume Name-
-vserverparameter are specified, the command displays detailed autodelete policy information about the specified volume. If this parameter is specified by itself, the command displays autodelete policy information about all volumes matching the specified name. [-enabled {true|false}]- Enabled-
If this parameter is specified, the command displays information about autodelete policies that match the specified parameter value.
[-commitment {try|disrupt|destroy}]- Commitment-
If this parameter is specified, the command displays information about autodelete policies that match the specified commitment value.
[-defer-delete {scheduled|user_created|prefix|none}]- Defer Delete-
If this parameter is specified, the command displays information about autodelete policies that match the specified defer deletion criterion.
[-delete-order {newest_first|oldest_first}]- Delete Order-
If this parameter is specified, the command displays information about autodelete policies that match the specified deletion order.
[-defer-delete-prefix <text>]- Defer Delete Prefix-
If this parameter is specified, the command displays information about autodelete policies that match the prefix used for deferring deletion.
[-target-free-space <percent>]- Target Free Space-
If this parameter is specified, the command displays information about autodelete policies that match the specified target free space.
[-trigger {volume|snap_reserve|(DEPRECATED)-space_reserve}]- Trigger-
If this parameter is specified, the command displays information about autodelete policies that match the specified trigger condition.
[-destroy-list <text>]- Destroy List-
If this parameter is specified, the command displays information about autodelete policies that match the specified value.
[-is-constituent {true|false}]- Is Constituent Volume-
If this parameter is specified, the command displays information about autodelete policies for the constituent volumes of FlexGroup volumes.
The following example displays snapshot autodelete policy settings for volume vol3 which is inside the Vserver vs0:
cluster1::> volume snapshot autodelete show -vserver vs0 -volume vol3
Vserver Volume Option Name Option Value
vs0 vol3
Enabled false
Commitment try
Trigger volume
Target Free Space 20%
Delete Order oldest_first
Defer Delete user_created
Defer Delete Prefix (not specified)
Destroy List none
