Command reference
security login group show
Display group configurations
This command displays the configured groups.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
Selects the groups associated with the Vserver that matches this parameter value.
[-name <text>] - Group Name
Selects the groups associated with the name that matches this parameter value.
[-type <entra>] - Group Type
Selects the groups associated with the type that matches this parameter value.
[-id <integer>] - Group ID
Selects the groups associated with the group id that matches this parameter value.
[-uuid <UUID>] - Group UUID
Selects the groups associated with the uuid that matches this parameter value.
[-created <MM/DD/YYYY HH:MM:SS>] - Create Timestamp
Selects the groups associated with the created time that matches this parameter value.
[-comment <text>] - Comment
Selects the groups associated with the comment that matches this parameter value.
[-scope {svm|cluster}] - Cluster or SVM
Selects the groups associated with the scope that matches this parameter value.
The example below displays the "Eng_group" group information of the Vserver VS1.
cluster1::> security login group show -name Eng_group -vserver VS1
                    Vserver: VS1
                 Group Name: Eng_group
                   Group ID: 10
                 Group Type: entra
                    Comment: Engineering Group
