system feature-usage show-history
Display Feature Usage History
Display feature usage information in the cluster on a per-node and per-week basis.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Displays feature usage information for the specified node name.
[-serial-number <Node Serial Number>]- Node Serial Number-
Displays feature usage information for the specified serial number.
[-feature-name <Managed Feature>]- Feature Name-
Displays feature usage information for the specified feature name.
[-week-number <Sequence Number>]- Week Number-
Displays feature usage information for the specified week number.
[-usage-status {not-used|configured|in-use|not-available}]- Usage Status-
Displays feature usage information that matches the specified usage status.
[-date-collected <MM/DD/YYYY HH:MM:SS>]- Collection Date-
Displays feature usage information that is collected on the day matching the specified date.
[-owner <text>]- Owner-
Displays feature usage information for the specified owner name.
[-feature-message <text>]- Feature Message-
Displays feature usage information that contains the specified feature message.
The following example displays a usage output filtered by the serial number and feature name:
cluster1::> system feature-usage show-history -serial-number 1-81-0000000000000001122334455 -feature-name NFS
Node Serial Number: 1-81-0000000000000001122334455
Feature Name: NFS
Owner: node1
Week # Usage Status Date Collected Feature Message
4 in-use 01/22/13 10:00:00
3 in-use 01/15/13 10:00:00
2 not-used 01/08/13 10:00:00
1 configured 01/01/13 10:00:00
4 entries were displayed.
