system feature-usage show-history
PDF of this doc site
Creating your file...
Display Feature Usage History
Display feature usage information in the cluster on a per-node and per-week basis.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Displays feature usage information for the specified node name.
[-serial-number <Node Serial Number>]
- Node Serial Number-
Displays feature usage information for the specified serial number.
[-feature-name <Managed Feature>]
- Feature Name-
Displays feature usage information for the specified feature name.
[-week-number <Sequence Number>]
- Week Number-
Displays feature usage information for the specified week number.
[-usage-status {not-used|configured|in-use|not-available}]
- Usage Status-
Displays feature usage information that matches the specified usage status.
[-date-collected <MM/DD/YYYY HH:MM:SS>]
- Collection Date-
Displays feature usage information that is collected on the day matching the specified date.
[-owner <text>]
- Owner-
Displays feature usage information for the specified owner name.
[-feature-message <text>]
- Feature Message-
Displays feature usage information that contains the specified feature message.
The following example displays a usage output filtered by the serial number and feature name:
cluster1::> system feature-usage show-history -serial-number 1-81-0000000000000001122334455 -feature-name NFS Node Serial Number: 1-81-0000000000000001122334455 Feature Name: NFS Owner: node1 Week # Usage Status Date Collected Feature Message ------ ----------------- -------------------- -------------------------- 4 in-use 01/22/13 10:00:00 3 in-use 01/15/13 10:00:00 2 not-used 01/08/13 10:00:00 1 configured 01/01/13 10:00:00 4 entries were displayed.
