vserver services ndmp show
Display NDMP Properties
This command is used to display NDMP options on Vservers.
A combination of parameters can be optionally specified so as to list only a subset of Vservers where specific values of NDMP options are met. A short description of each of the options is provided in the parameters section.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver-
If this parameter is specified, the command displays NDMP options for that Vserver alone.
[-maxversion <integer>]- NDMP Version-
If this parameter is specified, the command displays NDMP options for Vservers where the highest NDMP protocol version supported matches the specified input value. The only supported value is 4.
[-ignore-ctime-enabled {true|false}]- Ignore Ctime-
If this parameter is specified, the command displays NDMP options for Vservers, where the value for
ignore-ctime-enabledmatches the specified input value.This option, when
true, allows user to exclude files with ctime changed from storage system' incremental dumps since other processes like virus scanning often alter the ctime of files. When this option isfalse, backup on the Vserver will include all files with a change or modified time later then the last dump in the previous level dump. The default value isfalse. This option is persistent across reboots.Most WIN32 APIs are often unaware of the "last changed time", ctime, they often incorrectly set a later time for files, causing these files to be included in the Vserver's incremental dumps, making the incremental dump very large. This is partially defying the purpose of having incremental dumps, since one uses incremental dumps to speed up the backup by only dumping files that were truly changed since the last backup.
The possible value for this parameter is either true or false.
[-offset-map-enable {true|false}]- Enable Offset Map-
offset-map-enablematches the specified input value.This option is used to enable or disable generation of the inode offset map during NDMP based dump backups. The offset map is required to perform Enhanced Direct Access Restore (DAR) on the backup data. Enhanced DAR provides support for directory DAR and DAR of files with NT streams. The default value for this option is
true. This option is persistent across reboots.The possible value for this parameter is either true or false.
[-tcpnodelay {true|false}]- Enable TCP Nodelay-
tcpnodelaymatches the specified input value.This parameter Enables/Disables the TCPNODELAY configuration parameter for the socket between the Vserver and the DMA. When set to true, the Nagle algorithm is disabled and small packets are sent immediately rather than held and bundled with other small packets. This optimizes the system for response time rather than throughput.
This option becomes active when the next NDMP session starts. Existing sessions are unaffected. The default value for this option is
false. This option is persistent across reboots.The possible value for this parameter is either true or false.
[-tcpwinsize <integer>]- TCP Window Size-
tcpwinsizematches the specified input value.This option shows the TCP buffer size of the NDMP data connection.The minimum and maximum values are 8192(8K) and 262,144(256K), respectively. The default value for this option is 32768(32K).
The possible value for this parameter is a number between 8192(8K) and 262,144(256K).
[-data-port-range <text>]- Data Port Range-
data-port-rangematches the specified input value.This option shows the port range on which the NDMP server can listen for data connections.
The format of this option is
start_port - end_portstart_port, end_port can have values between [1024-65535]; start_port must be lesser than or equal to end_port. If a valid range is specified, NDMP uses a port within that range to listen for data connections. A listen request fails if no ports in the specified range are free.This option is modifiable only from the admin Vserver context and the said option is applicable for all the data Vservers and the admin Vserver. For example, if the value of the above option is set with 2000-3000, the same value will be applicable throughout the cluster. The value
allimplies that any available port can be used to listen for data connections. The default value for this option isall. This option is persistent across reboots.The value for this option is displayed in the format {<start_port>-<end port> | all }- where start_port, end_port can have values between [1024-65535]; start_port must be lesser than or equal to end_port.
[-backup-log-enable {true|false}]- Enable Backup Log-
>backup-log-enablematches the specified input value.Backup logging captures important events during dump/restore and records them in /mroot/etc/log/backup on the root volume. The default value for this option is
false. This option is persistent across reboots.The possible value for this parameter is true/false.
[-per-qtree-exclude-enable {true|false}]- Enable per Qtree Exclusion-
per-qtree-exclude-enablematches the specified input value.If this option is
true, users can specify exclude list on a per qtree basis to be excluded from backup. This exclude list will override any values already present due to 'EXCLUDE' environment variable . The user can specify the exclusion list through a .exclude_list file which resides at the root of the qtree. The exclusion list can be a list of files or files that match a specified pattern. The default value for this option isfalse. This option is persistent across reboots.The possible value for this parameter is either true or false.
[-authtype <NDMP Authentication types>,…]- Authentication Type-
authtypematches the specified input value.Allows the administrator to choose the authentication method. NDMP supports three authentication types: challenge, plaintext and plaintext_sso. The plaintext_sso authentication type is mutually exclusive with the other authentication types. By setting the authentication type as plaintext_sso, the actual password for the user can be used to authenticate instead of having to generate an NDMP specific password. The default of this option is
challenge. This option is persistent across reboots.The possible value for this parameter can be {challenge | plaintext | plaintext_sso | challenge, plaintext | plaintext, challenge}.
[-debug-enable {true|false}]- Enable Debug (privilege: advanced)-
debug-enablematches the specified input value.This option enables debug logging for NDMP. Debug messages will be logged to the ndmpd log file /mroot/etc/log/mlog/ndmpd.log . The default value for this option is
false.This option is persistent across reboots.The possible value for this parameter is either true or false.
[-debug-filter <text>]- Debug Filter (privilege: advanced)-
debug-filtermatches the specified input value.This option controls the NDMP modules for which debug logging is to be enabled. option-value can take five values for this option : all, none, normal, backend or "filter-expression".
allenables debug logging for all modules.nonedisables debug logging for all modules. It is equivalent tomodify -vserver vserver_name -debug-enable false.normalis a shortcut option that enables debug logging for all modules except verbose and io_loop. The equivalent filter string is all-verbose-io_loop.backendis a short cut option that enables debug logging for all modules except verbose, io_loop, ndmps and ndmpd. The equivalent filter string is all-verbose-io_loop-ndmps-ndmpp.(filter-expression)is a combination of one or more modules for which debug logs needs to be enabled. Multiple module names can be combined using following operators :-
- to remove the given module from the list of specified modules in the filter string. For example the filter all-ndmpp will enable debug logging for all modules but not ndmpp.
^ to add the given module or modules to the list of modules specified in the filter string. For example the filter ndmppmoverdata will enable debug logging for ndmpp, mover and data.
The possible module names and a brief description is given below:-
+--------------+-------------------------------------+ | Modules | Description | +--------------+-------------------------------------+ | verbose | verbose message | | io | I/O process loop | | io_loop | I/O process loop verbose messages | | ndmps | NDMP service | | ndmpp | NDMP Protocol | | rpc | General RPC service | | fdc_rpc | RPC to FC driver service | | auth | Authentication | | mover | NDMP MOVER (tape I/O) | | data | NDMP DATA (backup/restore) | | scsi | NDMP SCSI (robot/tape ops) | | bkup_rpc | RPC to Backup service client | | bkup_rpc_s | RPC to Backup service server | | conf | Debug configure/reconfigure | | dblade | Dblade specific messages | | timer | NDMP server timeout messages | | vldb | VLDB service | | smf | SMF Gateway messages | | common | NDMP common state | | ext | NDMP extensions messages | | ndmprpc | NDMP Mhost RPC server | +--------------+-------------------------------------+The default value for this option is
none. This option is persistent across reboots.The possible value for this parameter can be {all | none | normal | backend |'filter-expression'}.
[-dump-logical-find <text>]- Enable Logical Find for Dump (privilege: advanced)-
dump-logical-findmatches the specified input value.This option specifies whether to follow inode-file walk or tree walk for phase I of the dump. Choosing inode-file walk or tree walk affects the performance of the dump. This option can take following values:
If
defaultis specified, then level 0 and incremental volume as well as qtree dumps will use inode walk. All the subtree dumps will use tree walk.If
alwaysis specified, all dumps will follow treewalk.A
comma-separatedlist of values in any combination from the following list:-
vol_baseline: Level 0 full volume backup will follow treewalk.
vol_incr: Incremental full volume backup will follow treewalk.
qtree_baseline: Level 0 qtree backup will follow treewalk.
qtree_incr: Incremental qtree backup will follow treewalk.
default. This option is persistent across reboots.The possible value for this parameter could be {default | always | 'vol_baseline' | 'vol_baseline,qtree_baseline' | …}.
[-abort-on-disk-error {true|false}]- Enable Abort on Disk Error (privilege: advanced)-
abort-on-disk-errormatches the specified input value.If this option is
true, dump will abort the backup operation on detection of irrecoverable data blocks in user files. If this option isfalse, dump will proceed with backup operation - even if irrecoverable data blocks in user files are detected. On detection of irrecoverable data blocks, dump will send a log message to DMA and also log an entry in /mroot/etc/log/backup file. The default value for this option isfalse. This option is persistent across reboots.The value for this parameter is either true or false.
[-fh-dir-retry-interval <integer>]- FH Throttle Value for Dir (privilege: advanced)-
fh-dir-retry-intervalmatches the specified input value.NDMP protocol sends back file history information for all directories in phase 3 of dump to DMA. In the presence of slow DMA or high latency networks, the amount of file history being generated exceeds the amount being consumed by the DMA. To handle a slow reader, a flow control mechanism is now introduced where file history generation is throttled when a DMA is slow in consuming them. The value for this option indicates how frequently should the file history be resent if it was throttled. The default value is 250 milliseconds. This option is persistent across reboots.
The value for this parameter is a number.
[-fh-node-retry-interval <integer>]- FH Throttle Value for Node (privilege: advanced)-
fh-node-retry-intervalmatches the specified input value.NDMP protocol sends back file history information for all files in phase 4 of dump to DMA. In the presence of slow DMA or high latency networks, the amount of file history being generated exceeds the amount being consumed by the DMA. To handle slow reader conditions, a flow control mechanism is now introduced where file history generation is throttled when a DMA is slow in consuming them. The value for this option indicates how frequently should the file history be resent if it was throttled. The default value is 250 milliseconds. This option is persistent across reboots.
[-restore-vm-cache-size <integer>]- Restore VM File Cache Size (privilege: advanced)-
restore-vm-cache-sizematches the specified input value.This option mandates the number of WAFL buffers pinned in memory by various meta-files used by logical restore. The minimum and maximum values are 4 and 1024, respectively. The default value for this option is 64. This option is persistent across reboots.
Depending on the value of this option, various meta-files are assigned a number of WAFL buffers that need to be pinned in memory.
+-----------------+---------------------------------+ | Meta-filename | Number of WAFL buffers to | | | be pinned in memory | +-----------------+---------------------------------+ | dumpmap | ndmpd.restore.vm_cache_size | | filemap | ndmpd.restore.vm_cache_size | | aclfile_map | ndmpd.restore.vm_cache_size | | inomap | ndmpd.restore.vm_cache_size / 2 | | basemap | ndmpd.restore.vm_cache_size / 2 | | flipmap | ndmpd.restore.vm_cache_size / 2 | | revmap | ndmpd.restore.vm_cache_size / 2 | | clrimap | ndmpd.restore.vm_cache_size / 4 | | mfp_for_inotab | ndmpd.restore.vm_cache_size / 4 | | map | ndmpd.restore.vm_cache_size / 4 | | offsetfile_map | ndmpd.restore.vm_cache_size / 4 | +-----------------+---------------------------------+The possible value for this parameter is a number between 4 and 1024.
[-enable {true|false}]- Enable NDMP on Vserver-
enablematches the specified input value.When the option is set to
true, the NDMP daemon handles requests, and when set tofalse, the NDMP daemon does not handle requests. Enabling and disabling the option is equivalent to executing the following commands:vserver services ndmp onandvserver services ndmp offrespectively. This option is persistent across reboots. The default value of this option isfalse.The value for this parameter is either true or false.
[-preferred-interface-role {undef|cluster|data|node-mgmt|intercluster|cluster-mgmt}]- Preferred Interface Role-
preferred-interface-rolematches the specified input value.This option allows the user to specify the preferred Logical Interface (LIF) role while establishing an NDMP data connection channel. The NDMP data server or the NDMP mover establishes a data channel from the node that owns the volume or the tape device respectively. This option is used on the node that owns the volume or the tape device. The order of IP addresses that are used to establish the data connection depends on the order of LIF roles specified in this option.
The default value for this option for the admin Vserver is
intercluster, cluster-mgmt, node-mgmtThe default value for this option for a data Vserver is
intercluster, data. [-secondary-debug-filter <text>]- Secondary Debug Filter (privilege: advanced)-
secondary-debug-filtermatches the specified input value.This option allows control on NDMP debug logging. This option takes a comma separated tag=value pairs. The supported tag is
IPADDRwhich can be used to specify Vserver IP addresses for which NDMP debugging is required. If this option is set and the optiondebug-enableis set to true, then the debug-filter option is applicable to sessions whose control connection IP addresses match the IP addresses that are listed in the option. If this option is not set, the debug filter is applicable to all Vserver sessions. By default, this option does not have a value set. [-is-secure-control-connection-enabled {true|false}]- Is Secure Control Connection Enabled-
is-secure-control-connection-enabledmatches the specified input value.This option enables NDMP service to accept control connections over secure sockets on TCP port 30000. This option is persistent across reboots. The default value of this option is
false.
The following example displays NDMP options for the Vserver(s).
cluster1::> vserver services ndmp show VServer Enabled Authentication type ------------- --------- ------------------- cluster true plaintext vs1 true plaintext vs2 true plaintext 3 entries were displayed. cluster1::>
The following example displays detailed NDMP options for a Vserver.
cluster1::*> vserver services ndmp show -vserver vs1 -instance
Vserver: vs1
NDMP Version: 4
Ignore Ctime: false
Enable Offset Map: true
Enable TCP Nodelay: false
TCP Window Size: 32768
Data Port Range: all
Enable Backup Log: true
Enable per Qtree Exclusion: false
Authentication Type: plaintext
Enable Debug: false
Debug Filter: none
Enable Logical Find for Dump: default
Enable Abort on Disk Error: false
FH Throttle Value for Dir: 250
FH Throttle Value for Node: 250
Restore VM File Cache Size: 64
Enable Logging of VM Stats for Dump: false
Enable NDMP on Vserver: true
Preferred Interface Role: intercluster, data
Secondary Debug Filter: -
Is Secure Control Connection Enabled: false
cluster1::*>
