security anti-ransomware volume event-log show
Show anti-ransomware event-log for volumes
The security anti-ransomware volume event-log command.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver name>]- Vserver Name
This parameter specifies the Vserver of anti-ransomware enabled volume.
- [-volume <volume name>]- Volume Name
This parameter specifies the anti-ransomware enabled volume.
- [-is-enabled-on-new-file-extension-seen {true|false}]- Is Enabled on New File Extension Seen
This parameter indicates whether an alert event is generated on creation of files with new extensions.
- [-is-enabled-on-snapshot-copy-creation {true|false}]- Is Enabled on Snapshot Copy Creation
This parameter indicates whether an alert event is generated when a snapshot is created.
 PDFs
PDFs
