security anti-ransomware volume event-log show
Show anti-ransomware event-log for volumes
The security anti-ransomware volume event-log command.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name-
This parameter specifies the Vserver of anti-ransomware enabled volume.
[-volume <volume name>]- Volume Name-
This parameter specifies the anti-ransomware enabled volume.
[-is-enabled-on-new-file-extension-seen {true|false}]- Is Enabled on New File Extension Seen-
This parameter indicates whether an alert event is enabled on creation of files with new extensions.
[-is-enabled-on-snapshot-copy-creation {true|false}]- Is Enabled on Snapshot Copy Creation-
This parameter indicates whether an alert event is enabled when a Snapshot copy is created.
