ONTAP commands
security anti-ransomware volume event-log show
Show anti-ransomware event-log for volumes
The security anti-ransomware volume event-log command.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver Name
This parameter specifies the Vserver of anti-ransomware enabled volume.
[-volume <volume name>] - Volume Name
This parameter specifies the anti-ransomware enabled volume.
[-is-enabled-on-new-file-extension-seen {true|false}] - Is Enabled on New File Extension Seen
This parameter indicates whether an alert event is generated on creation of files with new extensions.
[-is-enabled-on-snapshot-copy-creation {true|false}] - Is Enabled on Snapshot Copy Creation
This parameter indicates whether an alert event is generated when a snapshot is created.
